The phone won't charge after battery overheating
the phone has stalled during use and the battery has overheated, when the charger is plugged in i get the message: battery alert... the battery temperature is abnormal,charging has been stopped.
Try leaving the device off for a day or so.
If it does not work:
Consider getting it repaired for a battery replacement. Remember to not play with it on for too long, turn it off if not playing and do not overcharge it.
このアンサーは役に立ちましたか?
I found a 1.1kohm dead rezistor on pcb near the battery connector ,i replaced and work fine.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 20
今までの合計 3,472
4 件のコメント
@rosioaratudor Have you tried turning off your phone for a few hours until the battery is cool, and then turning it back on? and doing what you just did before?
Vinicius Lupas さんによる
Battery paused exceeded ideal temperature range
Nancy Campbell さんによる
Yes it has refused to turn on completely
Kadiatu Kabba さんによる
I have tried all the above questions
Kadiatu Kabba さんによる
