メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
Not another iPhone white screen problem!, but sorry I have one.
i tried to reset it by holding down both buttons and waiting for it to start up and there's still the white screen. whenever i turn on the iphone, even though there is a white screen, i can unlock it and the unlocking sound indicates it when i touch and slide where the unlock button is located according to memory. to make it more descriptive, i uploaded a video of the problem with a link here. i would be really grateful if you know whats exactly the problem and with a solution. i might even upload further videos to better help you see the problem with this iphone. please help me fix it.
http://www.youtube.com/watch?v=qjkFmVamc...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
4件の回答
ベストアンサー
if the phone is still in warranty and you have not opened it before, just take it back to apple, to get it replaced/repaired.
if it is not under warranty anymore, just order a new screen and replace it.
here is the guide: iPhone 3GS Display Replacement
let us know, if any success...
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
are you sure that i just need to replace the screen? did you check my youtube uploaded video out in the link which i provided there?
さんによる
no, i am not sure. as you did not give us any useful informations. did you ever open the phone and attempt any repairs?
if it suffered a fall, it might have been damaged. some coil inside could have been damaged. but my guess would be faulty screen. digitiser works, as you can use it and it is confirmed to be working. can you ask any of your friends, to try to use their screen assembly and just fit it instead of yours?
and yes, i have checked the video...
さんによる
+ for endurance
さんによる
i did drop it once. it seemed alright as soon as i checked to see what might have gone wrong. but some time after that the screen seemed unclear, almost sort of foggy/cloudy and shaking/shimmering too. while it was doing that, i could still see the icons and everything was working except the shaky screen. i tried turning it on and off repeatedly for some time to see it go back to normal. then one day, it was totally white. i tried restoring, resetting it. nothing worked. it's still white at the moment. so is this better/all the info you need?
さんによる
palo killer, i am still considering your final verdict. so?
さんによる
2件以上のコメントを表示
コメントを追加
Palokiller is right. You need to replace your LCD. You could open the phone and check connector 1 is on properly. A white screen = dead screen.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I also had this white screen on my 3gs, but I had opened my phone so im quite sure I damaged it myself. when starting up, the phone turned completely white after the apple logo. My fix; I replaced connector number 3. Try replacing the screen as palokiller suggested.. I searched for an answer for days when I had this problem, what I found was that white screen can occur for many reasons, so its hard to tell what has been damaged. Try replacing parts one by one:) If you or anyone else have a spare minute, I need an answer to this question;
Why is my sound gone?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Sounds like your screen is messed up.
Try a DFU restore, otherwise take it to the store.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
tenzin さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 7,654
