メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2687回答 すべてを表示
Why wont my phone work? read description...
I cracked my phone a month ago. Then,i recently dropped it in water. I put it in rice, then i turned it on and it worked but after that, my screen started to get white lines, So, i put it back in the rice. A few hours later i went to turn it back on but, it turned on . But, the screen turned it all black and isn't responsive.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
@xx_tt_xx you can absolutely skip the rice. IT DOES NOT WORK Rice does absolutely nothing for water damage. It does not prevent corrosion, it does not fix your phone. You are only wasting valuable time!
As with any other liquid immersed device you need to follow a few steps for proper trouble shooting.
Stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.
The very first step I would take is to disassemble your phone. Use this teardown to help you disassemble your phone. Take a careful and close look at all components and connectors. Truly assess the damage. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. Once you got the gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for a Apple iPhone 3G but it is still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning. Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. Do not use drinking water, if you need to use water, use sterile water. Also, you do not need to leave it to dry for a day. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water. The importance here is the cleaning. It would of course be best to get it professionally cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. After that reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It is possible that your LCD is destroyed from the water damage but it is also possible that you have failed components on your motherboard that may need to be replaced. So once you followed all the aforementioned steps and replacement, replace the display assembly as well but do not bet on that alone.
iPhoneの画像
ガイド
iPhoneの水濡れ・水没ダメージからの復旧方法
難易度:
難しい
1 - 2 hours
iPhone 6sの画像
ガイド
iPhone 6sの分解
難易度:
中レベル
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
If the Phone Turn on but Your Screen is black and shows nothing it's probably your Screen Has been been broken and burned and you have to change it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tatum Tavares さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 35
