Replaced touch screen still doesn't work, not a ribbon problem
Really stuck on this one. Originally the Ipod had a white screen but upon doing a restore the ipod showed up fine, but then the touch screen stopped working. Tried restoring it again but no luck. So I went into it and replaced the touch screen. No luck. Checked for water damage-found none. Took the entire logic board out, cleaned it with rubbing alcohol, reattached everything, still no luck. Everything works apart from the touch screen. What to do? Is the logic board fried?
If it is definitely a logic board problem, is it possible to replace only the top part of the logic board (where the digitiser connection is located)?
この質問は役に立ちましたか?
