メインコンテンツにスキップ
モデル番号はA1236で4もしくは8GB容量
134回答 すべてを表示
Ipod is dead it wont charge and i cant put songs on it how do i fix it
my Ipod is unrecognized by itunes and therefor it won't charge and i can't reset it. i also can't put songs on it. when i plug it in, it says connect to power and shows the apple sign then shows the front menu then says connect to power how in the world can i fix it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
1件のコメント
mine also same...wat shud i do?
さんによる
コメントを追加
2件の回答
ベストアンサー
Most likely a bad battery, get a new one here.
このアンサーは役に立ちましたか?
スコア 5
2 件のコメント:
さんによる
コメントを追加
Try a reset. Press centre button and menu. Hold for a few seconds to see if apple comes on screen.
If that doesn't work plug it into a computer via a USB lead to recharge it. Docks and PSU type chargers may not work if it is dead flat.
Update
I am talking from my own experience. I had a dead Nano and it would not charge from a PSU or dock, but did from a computer. Possibly it was because it was not an Apple psu. I would advise anyone with a dead Nano to try recharging from all sources.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
sbdfhs, you have it reversed. A computer USB output is no less than 4.75 V and no more than 5.25 V and 500mA. It will NOT charge a battery that is below 2.7V You WILL have to use at least an AC charger since the spces on those are Input 100-240V - 0.15A (0.15A) 50-60hz
Output 5V --- 1A So your answer is very misleading. May be an edit would be nice:-)
さんによる
コメントを追加
回答を追加する
tyler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,832
