I can't access my files
Why can't I access my files it say something is turned off or not installed?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The only thing I can think of without seeing the device is that one of the main programs that utilizes whatever you're are attempting to open is disabled OR needs to be updated in the play store.
If you go to settings > applications> and look for the disabled and/or check for a software update, check the play store for application updates that may run the file you're attempting to open.
The only application I can think of for the S5 is either called Memo/Notes.
このアンサーは役に立ちましたか?
It works now thanks
Glad to hear it!
Thanks iowloakkalsl
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 1,414
7 件のコメント
Can you be more specific about what you are trying to access
rohith rangaraju さんによる
If I go to settings look in storage at explore nothing that I try to open will says it's turned off or not installed
Bill さんによる
What's turned off or not installed? We can't see what you can, so you'll need to give us as much information as possible.
George A. さんによる
@pccheese you're doin great, kid. Keep goin
iMedic さんによる
@bmur98, do you see a "My Files" app in the phone? That can view your files and open your folders normally.
S W さんによる
2件以上のコメントを表示
