メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年10月26日にリリースされた第4世代のSurface Proタブレット。
Microsoft surface pro 4 mother board schematic help
i need the motherboard schematic for my Microsoft surface pro 4, i7
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
4 件のコメント:
Hi suface not poweron iwant shcmatice
さんによる
Hello i need too surface pro 4 schematic (datasheet) you found?
さんによる
hi, could you make it 16gb ram? i have a surface pro 4 and i wanna replace the rams. how did you do that? did you need to replace resistors?
さんによる
Hello,
Unfortunately I haven' t got the schematic. Also for surface 1 they were not available.
But if anybody have got them, I would also take them.
But I' ve also got another question.
Is your surface fitted with 8 or 16gb of ram?
I ask because I want to upgrade my Ram from 4 to 16gb and I also ordered the necessary chips already.
These are K4EBE304EB-EGCF ones from Samsung.
But now I'm not sure whether it is necessary to equip also the marked areas in the pictures with components.
https://picload.org/view/dgrpgrdr/pictur...
https://picload.org/view/dgrpgrda/pictur...
Now my question for you is the following. If you have removed your mainboard, could you please take a look at the marked free areas in the picture and check if there are any components are mounted. And if there are should be any maybe you could take a picture or tell me what' s there because there are absolutely no pictures in the inernet.
Thank you very much for your help.
さんによる
コメントを追加
1 件の回答
I have it, write to my email and I will send it to you. manuelbrito162@gmail.com
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Bashar Aljawrneh さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 24
今までの合計 3,795
