Why my ring/silent switch doesn't work?
So...I have my iPhone 6 since the launching of it,and it now started to not responding when i try to switch to silent it does not work.Any fix?
Does it give you any feedback when you flip the switch like it normally would or is it hard to press?
It's possible the activator switch went out and you require a replacement Volume/Power button switch. The repair isn't the easiest to do but it is possible.
このアンサーは役に立ちましたか?
Check your settings - the switch may be set to lock rotation instead of mute the ringer.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 14,189
