メインコンテンツにスキップ
Code says Int and won't stop the rinse cycle
The error message that is being displayed is "Int." It continues to cycle the rinse cycle. When I tried holding the power button it just starts the rinsing cycle again. Please help! Thank you!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@kaykay10 "The "int" means interrupt. The "int" will display when the user presses "Stop" trying to interrupt the "Clean Cycle" and the "INT" will not go away when pressing start and will not resume the cycle.
If necessary the cleaning cycle may be interrupted by pressing the STOP button. However, this will not immediately stop the cycle. The machine will display "int" (interrupt) and continue with several rinses and drain steps to ensure that all remaining bleach is rinsed from the washer. When the Clean washer cycle is paused "INT" the control board's software stores position of the cycle; even if the power is disconnected from the unit the control still saves the position of the cycle.
Disconnecting the power supply from the machine will not clear the "INT". It will take the unit 3-5 seconds to resume the cycle once the start keys is pressed to resume the cycle. If the unit does not resume within 3-5 seconds check the connections between the user interface and the main control board." from here
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
How do I get my kenmore series 600 to drain? It won't finish spinning and draining the las couple inches of water
さんによる
Hi Oldturkey03,
I am having the same "Int" problem and was trying to read your response as to how to fixt it yet when I click "here" nothing comes out. Please help!
さんによる
コメントを追加
回答を追加する
Kay Knapp さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 57
今までの合計 8,309
