( *Removed the Mag-Safe adapter. Press and hold the power button for 5 seconds. )
( *Reconnect the battery. )
( *As soon as you reconnect the mag-safe you should get a spontaneous reboot. )
*Test Complete - Zero Response
( w/o pressing start button )
2nd Time- test repeated -
( w/ start button applied )
Zero Response.
This concludes - Game Over
There are 10 very interesting gold plated telescopic pins on mother board - that bump contact bottom cover.. Never noticed this detail before.
Clues were odd pattern of markings on the cover from factory.
6 件のコメント
I switched this to its own question as they were different machines and answering in the previous question would have caused confusion.
mayer さんによる
ok, I'm on 1st edition iPad, and it's difficult navigating.
Philscbx さんによる
Only a trial version of Kaspersky used in the past,,
And what a battle ripping that out of deep files this took hours then waste bucket had to be fooled at very moment of startup, to actually dump the waste,, let laptop fully finish start, deleting was fully blocked of any of trace files.
That's pretty brutal tactics.
Philscbx さんによる
This is confusing question you asked:
Did you get a full install of ElCapitan?
How can you not get full load? And actually get machine to run.
Its taken roughly 3 months to analyze just what ElCapo is and isn't.
One thing for sure -
Huge Mistake.
Remember the good old days of 05' G4,,
We actually had brushed aluminum file folders,, lol.
I still have PowerBook, and actually works, but I doubt it can get here.
Philscbx さんによる
Well, things really got weird in the last hour..
On assembly of bottom cover as its in my lap I started to notice heat transfer to bottom cover as the last cover screw is inserted, not because of screw just the timing of..
Removed cover, disconnected battery, install cover.
( In one of my notes, when first drafted, I made note of this heat - top side never noticed before,, right when all this no response issue started.
( Possible nightmare pending"
when all was fine the night before I wake up the next morning tap space bar to wake him up, typical start screen is loading then a quick view of where I left off flashed before my eyes I think I tried to wake him again, the scene repeated the quick flash view of night before, and that's the last time it made any response.
Philscbx さんによる
1以上のコメントを表示
