2014年9月19日に発売されたこのiPhoneは4.7インチのスクリーンサイズでiPhone 6 Plusの縮小版です。
4687の回答 すべて表示
Will replacing the screen fix water damage?
My wife's sister's iPhone 6 got some water damage. You can see everything on the screen, but it has lines, and the left side doesn't respond to touch. I've replaced screens before, but usually after they've been cracked..not after water damage.
Will replacing the screen fix the issue or are there likely some internals that are damaged?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
i have the same issue that one side works except in my case theres no water damage mine fell and cracked i want to know if a new screen can fix that or is it an internal issue. this is good to know so i wont get charged double for something that can be fixed easily with a new screen
による
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
2回答
最も参考になった回答
The short answer is, there's no way to be sure just how deep the issues go without trying it. If you've taken all the necessary precautions, and opened it up, dried it out, and are sure it's ready to be operational, giving it a new display is likely worth a shot. If you get the display from iFixit, we have an amazing return policy where you can return it if it doesn't fix your issue, and you'd only be out shipping in the worst case.
Best of luck in your repair!
iPhone 6 Screen画像
製品
iPhone 6 Screen
$64.99
この回答は役に立ちましたか?
スコア 1
コメント:
You definitely need to address the previous water damage by having it properly cleaned. Removing the motherboard and shields, giving it a good ultrasonic cleaning and alcohol rinse. Then visually inspecting for any signs of burn marks or shorted components.
there could be corrosion around/under the FPC Connectors, IC Chips and other board components causing your issue...or as @soria pointed out, it could just need a Screen change "IF you've taken all the necessary precautions"...
による
コメントを追加
It’s not worth fixing get a refurbished I phone from Walmart.com
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Christian さん、ありがとうございました!
統計データを表示:
過去 24時間: 14
過去 7 日: 105
過去 30 日: 354
今までの合計 10,988
