Repairing the iPod nano A1236
My ipod keeps flickering his lights on and off, how can i repair this?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Respect Lord, first off I would try the least invasive way and that is by resetting the ipod http://support.apple.com/kb/ht1339 If that does not make a difference you might be looking toward replacing your LED first. It is relative inexpensive iPod nano (3rd Gen) Color Display the instructions are right here. iPod Nano 3rd Generation ディスプレイの交換 Of course make sure that your ribbon cable is connected properly, that no corrosion or other debris prevents the cable from making good contact. If this will not take care of the problem you may have to replace the logic board due to a back light issue. Good luck and let us know how it is going.
このアンサーは役に立ちましたか?
If replacing the LCD doesn't help, it might be some kind of issue directly on the motherboard.
このアンサーは役に立ちましたか?
My iPod does not work
Show me a black screen and I can not play songs
I think the battery is empty but after charging the battery also does not work
Please help me
このアンサーは役に立ちましたか?
oudai, click on the link on the right side of this page. "Ask a question" and give as much DETAIL as possible. Need to know which iPod you have, what you did to try to fix it and what the symptoms are...
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 7,274
