メインコンテンツにスキップ
Googleから発売された最初のAndroidスマートフォン、Pixel XL(モデル番号はG-2PW2100)は2016年10月20日に発売されました。5.5インチのAMOLEDディスプレイ、3450 mAhバッテリーが搭載され、32もしくは128GBストーレッジが選べます。
41の回答 すべて表示
WiFi, Pri. camera and flashlight do not function
...following "slight" water damage, i.e. splashed on face and puddle remained for several hours. not full immersion. unit was dried in rice then opened and carefully dried and cleaned by a professional. phone boots, xmits/recvs calls, etc. uBreakiFix (UW in Seattle) has been NO help. I'm 3rd owner and willing to learn (I'm somewhat capable as an Instrumentation Tech.)
seems like only a partial logic board failure but do these components share a commonality that I could/should pursue or look at more closely? ribbon cable connector corrosion or something?
'cause if you don't open it you don't really own it.
thanks in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
news; WiFi senses available networks but will not connect to any available options, secure or unsecure.
both cameras are non-functional. black screen. camera app "stops" when attempting to take a photo.
による
Cleaned in rice by a professional?
による
um, no. as stated, "...dried in rice THEN opened and carefully dried and cleaned by a professional". but why do you ask? do professionals not use this technique as well?
による
コメントを追加
MacBook Battery 修理キット
最低価格 $69.99
Buy Now
最低価格 $69.99
Buy Now
1回答
最も参考になった回答
Even though it's slightly water resistant, it must have penetrated the hull. So you'll need to do standard water damage cleaning. The first link is information on water damage. The second shows how to disassemble the phone, then the third shows proper water damage cleaning technique.
Electronics Water Damage
Google Pixel XL Teardown
iPhoneの水濡れ・水没ダメージからの復旧方法
Hope this helps!
iPhone画像
ガイド
難易度:
難しい
1 - 2 hours
Google Pixel XL画像
ガイド
難易度:
普通
この回答は役に立ちましたか?
スコア 2
コメント:
thanks George! went through the teardown link yesterday. I will check out the other two. "local" uBreakiFix claimed they did the water damage cleaning but then it was stuck in a boot loop. we're past that now so I'm trying further options.
による
コメントを追加
回答を追加する
Max Mason さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 90
