Replaced iPhone 6 Plus battery but it seems to still drain fast?
So I replaced my iPhone 6 Plus battery back in June. I decided to replace the battery because I got it from my cousin, and the original battery seemed to be draining pretty fast. So after replacing the battery, I still noticed that the battery would drain pretty quickly while using it. From what I can tell, sometimes it'll lose about 10% in an hour from about medium usage. The battery doesn't seem to drain if I'm not using it though. Honestly I'm at a lost as to what to do. All the googling I did hasn't turned up anything useful. It would be very much appreciated if someone could help me find a solution. I'm not sure if it could be the iOS it's on, or a hardware issue. I'm currently on iOS 10.3.3, but I was on 10.3.1 at the time of the battery replacement.
One more thing, while I was putting in the new battery, the battery connector cable got a little bent because it wasn't straight on with the opening. Could that possibly be the issue?
If anyone has an iPhone 6 Plus that can compare their battery life with mine, it would be helpful. Thank you.
この質問は役に立ちましたか?
4 件のコメント
I have iphone 6 and it's draining fast I'm replace my battery but still is draining fast I'm not used phone it though but it's draining 10% what to do
tiwarianmol222 さんによる
My replacement battery drains faster than the old battery I replaced
Frank Shore さんによる
My iPhone 6 is doing the same after a replacement battery. It’s still draining to 0% overnight without being on WiFi. I’ll Take the phone back to shop who said if the different battery doesn’t work then it must be the whatever inside the phone. Fed up with it.
Lynne Stoppard-Jones さんによる
Apple iPhones are a bunch of rubbish and a total ripoff!! In fact, the Apple Company itself has been proven to be a corrupt organisation for having deliberately placed defects into their updates that will slow down their older model phones, thus forcing users to upgrade to their latest models. Stay away from Apple!! The apple is rotten to the core!
Jacky J Jones さんによる
