Why does my camera turn off after 2-3 seconds from turning on.
I just charged the battery but when I turn it on, it turns off after 2-3 seconds.
mjragarcia most common issue for that is a stuck lens. Your camera will turn off if the lens does not fully extend etc. Check on here and let us know what you find. Use this guide Canon PowerShot SD 600 Lens and Motor Assmebly Replacement to start working on it.
このアンサーは役に立ちましたか?
Also maybe your camera's battery is not fully charged or dead. You can recharge the battery or consider replacing the battery.
このアンサーは役に立ちましたか?
過去 24時間: 9
過去 7 日: 43
過去 30 日: 180
今までの合計 4,410
2 件のコメント
Does it give a low battery indication before it shuts off?
Reed Crosby さんによる
yes it does but i put brand new batteries in
destanee さんによる
