After Battery Replacement, My iPhone 6 Keeps Rebooting.
I accidentally mixed up the screws that secure the charging cover. I put them back in the right place, but now my phone reboots after about 3 min. Is there anything I can do?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Turns out that the pins on the cable weren’t ligned up right. They were just a little bit off, and that’s what was causing the issue. We got them aligned right and everything worked.
このアンサーは役に立ちましたか?
Before you mixed up the screws, the iPhone booted properly and worked for more than 3 minutes?
このアンサーは役に立ちましたか?
Yes, before the repair it worked normally. I also noticed, it doesn't reboot while in Airplane mode for some reason.
The behavior of rebooting every 3 minutes is very odd. I dont believe (could be wrong) that mixing up those screws can do damage. If memory serves me right, the screws pass through the board and not directly onto where a longer screw would do damage.
Before the repair, you mean with the original battery? My guess: the replacement battery is a bad one. Try another battery please.
このアンサーは役に立ちましたか?
I put my origional battery back into my iPhone and even did a software restore, and it still reboots.
This looks to be a general problem on iPhones whenever thys battery replacement..I’m facing the same challenge. my 6s+ keeps restarting over and over and charge percentage is stuck after replacing the battery… gosh! quite irritating
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,097
