Anywhere to find replacement ports for this model of iMac?
So, to explain how this happened, I was transporting an iMac that someone gave me, but we forgot the screen wasn't screwed in or anything (it was loosely put together). About 3 connectors were bent or completely severed in the process that the display plug into. Everything else is in perfect shape. I planned to upgrade the iMac from an i3 to a better CPU, so I did proceed with that upgrade, but now I can't assemble it back up because there is no way for me to connect the display's connectors.
From what I can see on the board, what I need are the:
1) Internal Display connector
2) This unnamed connector that I can't seem to see the name or function of on the board, but I presume it supplies power???
'''3) The LCD Temp connector (possibly won't need it if I can still fit the connector in and just bend those 2 pins back into place).
TLDR; is there any place I can find these 3 connectors shown in the pictures/numbered above?
EDIT: I found the Internal Display connector on eBay. http://www.ebay.com/itm/330972398205
この質問は役に立ちましたか?
