Where can I get a joystick repaired on my special edition Xbox one con
My left joystick is broken and I want to get it fixed. Where would I be able to do so?
Hi!
You can replace the thumbstick yourself by following this guide. You will need to source a replacement partand a special Torx screwdriver. I've linked everything above.
If it isn't the thumbstick that's the problem, but the mechanism underneath, be sure to check these parts out.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 451
