High temperature after thermal paste replacement
I have replaced the thermal paste on my Macbook Air 2010 and am experiencing CPU Proximity high temperatures as per MacFan Control. Macbook was running hot when I would surf the net or watch video so I decided to replace the thermal paste which I have done dozens of times to Mac's and PC's.
I used Arctic Silver 5 and also applied a thin layer over the CPU and GPU and not on the heatsink. I didn't want to apply too much since it's conductive but I noticed with the original thermal paste (by apple) on both the chips was heavily coated prior to removing it. I see the heatsink on the Macbook Air is slighltly different as its not flat and wondering if maybe there is not enough thermal paste.
Applicion method I used to apply the thermal paste was I covered the chip all with a thin layer across the entire chip but not too much to spill on to the circut since Artctic Silver 5 is conductive.
I have restarted it few times, let it run and when it loads it runs close to 95 degrees celcius on CPU Proximity but drops to around 70 degrees idling . However CPU Diode is around 65 degrees and runs between 10-40 degrees higher.
I am thinking of maybe changing Thermal Paste to non-conductive and apply a lot to cover the chips heavily with the indented heatsink on Macbook Air's.
Has anyone else experienced similar issues with new thermal paste application?
この質問は役に立ちましたか?
1件のコメント
The assemblers At the factory can be messy. You don't need to emulate the way they do things.
Thermal paste is designed to fill the micro gaps between the heat sink plate and the top surface of the chip. Bleeding over the edge is both a waste and as you know can be a problem if the compound is electrically conductive.
Dan さんによる
