メインコンテンツにスキップ
初代Xboxは、Microsoftで初めて広く普及したビデオゲームコンソールです。上面と前面に「XBOX」の文字が入った黒いケースで、簡単に識別できます。修理は一般的な工具で簡単にできます。
170回答 すべてを表示
Bad Clock Capacitor, stops at clock screen
My xbox starts up, but skips the menus and goes straight to the clock set up. i cant do anything once i reach that point, and the controller does nothing (i've tried all ports). everthing freezes except for background. i've guessed the capacitor is bad but i researched and some dont work with out the capacitor. what do i do and how?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
When the clock capacitor fails on logic boards v1.1-1.5 they leak a corrosive acid that will do some damage if neglected. You will need to do some research to get your best guess on what version logic board you have. v1.6 does not have this issue when the capacitor fails.
Open up your Xbox and take a look around for that capacitor. Found it? Now Remove it! (You can just wiggle it back and forth to break it free) If it’s leaking clean up that acid ASAP as best you can. Alcohol and cotton will do and be careful it will burn your skin. Hopefully there isn’t any permanent damage to the board and it just needed a cleaning to get it going again.
Put the Xbox back together and see if it will let you get past the clock setup. If not; then actually replacing the capacitor may be required.
As for the controller not working; that makes me think there is some acid damage to the logic board. Your Xbox should function as normal without the capacitor; aside from resting the clock when Power is lost. I would start with the capacitor and any clean up then go from there. Eliminate one problem at a time.
iFixit has the teardowns and repair guides.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
ISHERWOOD75 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 665
