メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Westpointe MDC 45AEは、Midea American Corporationによって輸入された除湿機です。
Why is my humidifier overheating and not shutting off?
Last night my humidifier was overheating and would not shut off. I pulled the plug. This morning when I put the plug back in, it came on, but it was making a lot of noise, including a slowly "clanking" sound from the fan. Please advise.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@kahenn it is possible that you burned out some components on the controller board (start capacitors come to mind) as well as some motor damage (which may have started this issue). You would have to try to disassemble your dehumidifier and post some images of everything you find on the inside. Use this guide iFixitでの質問に画像を追加する方法 to add images to your question so we can try to find out more. Big issue with this will be that schematics are rarely available....
Bit of a concern is the recall of dehumidifiers Even so your model is not directly named, it could be a re-branded dehumidifier which might still show the same symptoms. So, if unsure let an electrician take a look at.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Thank you! Sounds to me like it would cost more to have it looked at and fixed than to buy a new one. It's at least seven years old, so there's no shame to it.
さんによる 共有
@kahenn most likely. I think I'd still tear it apart just to see what the damage is/was but I'd be a bit leery about the overheating issue etc.
さんによる 共有
コメントを追加
回答を追加する
Kathryn Henningson さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 24
今までの合計 805
