メインコンテンツにスキップ
2.4GHz, 2.7GHzもしくは2.8GHz クアッドコア Intel Core i7 プロセッサ (Turbo Boost 最大 3.8GHz) with 6MB 共有 L3 キャッシュ。
274回答 すべてを表示
stuck "L" key after spilling on keyboard
I spilled a Coke on the left half of my keyboard about 3 days ago. After the initial panic I quickly shut the machine down, turned if over to let excess run out and began dabbing with paper towel. I whipped thoroughly with damp cloth and let dry 2 days before turning on. I turned on after 2 days and found the "L" key was sticking causing the log-in screen to be filled with redundant L's. I shut down again, removed L key and scissor mechanism, cleaned with alcohol on Q-tip and reinstalled both parts.
Now 4 days later and the L key seems to work with it wants to. It will work properly 50% of the time but the other time it is either acting as if it is pressed or will not work at all.
What else can I do?
Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Replace the keyboard:
https://www.amazon.com/Replacement-US-Ke...
http://www.ebay.com/itm/Apple-Macbook-Pr...
Here's how:
https://www.youtube.com/watch?v=dU48RuxR...
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Scott Newcom さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 445
