メインコンテンツにスキップ
Screen does not glue
After changing the cracked screen, the new screen does not stick. A corner is bumped a little and screen didn't fit. I sanded the screen to fit. Even so, the screen is kind of loose, not firmly stick. is there any clip or case that holds the screen firm?
Thanks
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
PCラップトップ用バッテリー
An easy fix for a big power boost.
ショップを見る
PCラップトップ用バッテリー
ショップを見る
1回答
選択されたソリューション
There's a few things that can cause this and a few solutions.
First, you say one corner is bumped a little. If this is the bottom corner to the right of the home button then it means the digitizer flex cable has not been folded under properly and need to be adjusted.
Glue not sticking could be a few problems. The most likely is the frame not being clean enough, the other is poor quality adhesive. It also could be that it has been handled too much. In my shop my process is to warm the adhesive a bit with my heat gun before I press the digitizer into place, then once it is in and sitting flush I use the black paper clamps to keep it held tight for 1-2 hours so the adhesive can set well. Warning, DO NOT place a clamp over the home button or within an inch of it on each side as the glass there is quite easy to break.
If your adhesive is now not sticky due to too many attempts, I'd suggest removing it and using 3M double sided adhesive (9448A)
Hope this helps
この回答は役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
oscar molina さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 26
