メインコンテンツにスキップ
修理を始めるには
修理する権利
パーツ&ツール
2016年6月発売。モデル番号はA3003(EU)、A3000(中国と北米)。(以下の情報より https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
61の回答 すべてを表示
Can I change the battery of my OnePlus 3 to a OnePlus 3T battery?
Hello All
The battery of my OnePlus 3 is giving me issues these days. I was wondering if I could replace the current battery with the 3400mah OnePlus 3T battery.
OnePlus 3 comes with a 3000mah battery whereas OnePlus 3T comes with a 3400mah battery. On the other hand, the device tree of both the devices is almost the same and people are even able to apply OnePlus 3T body to a OnePlus 3
Please let me know if such activity is possible and how should I proceed with it
Thank You
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
Nintendo Switch 修理キット
ゲームを再開するための、早くて簡単な修理キット
Switch 修理キットページへ
Switch 修理キットページへ
5件の回答
最も参考になった回答
I try this and it doesn't work. Seem like Oneplus has patched it and it shows not compatible when I trying to boot up with a bigger battery
この回答は役に立ちましたか?
スコア 3
コメントを追加
I wish it was as simple as Jerryrigeverything made it out to be, but I tried this a month ago and it's just not worth it the hassle. It did work, but only with the earliest rom, as soon as I updated it or flashed a custom rom I would either get the Linux penguin logo or I'd get a message while booting that the battery was incompatible. If you're in need of a new battery I seriously recommend going with the original battery. :)
この回答は役に立ちましたか?
スコア 1
コメントを追加
Technically you can, but there is a very high possibility that it will only charge the battery to 3000mAh instead of 3400mAh. The batteries also have different voltages. (Watch JerryRigEverything’s video if you want to see it attempted: https://www.youtube.com/watch?v=n1sg2y8O...)
この回答は役に立ちましたか?
スコア 1
コメントを追加
First source:
According to the official Oneplus team, you can't swap the batteries back and forth.
Second Source:
According to Jerryrigeverything: https://youtu.be/n1sg2y8OuJs?t=140
In his video, he says that although you could technically swap the batteries back and forth, the software on the Oneplus 3 and the Oneplus 3t differ. This makes it so that even if you put a Oneplus 3t battery into a Oneplus 3, you wouldn't get the 400mah increase due to software charging restrictions to prevent overcharging.
In my opinion, I wouldn't bother swapping batteries because you probably won't see any difference in battery life, and the Oneplus 3 software wasn't designed to use the Oneplus 3t battery.
この回答は役に立ちましたか?
スコア 0
コメント:
I got one question: Isn't the software validating the charge of the battery by the voltage? With it doing that it will SAY 3000mAh and THINK you have 3000mAh but the voltage will drop not that fast and you will have a benefit anyway. + even if you cant use the extra 400 mAh wouldnt it be better for the battery not being maxxed all the time?
さんによる
Holy necro, but the way Oneplus increased the mAh capacity was by relaxing the voltage restrictions, so the battery is charged to a slightly higher voltage. The op3 would just not charge it to that higher voltage, if it didn't start complaining because the battery isn't the right model number.
さんによる
コメントを追加
The Oneplus 3T Battery has a slightly higher nominal voltage wich will interfere with the oneplus standard 3.8 nominal voltage. So it is not recommend and probably not possible to do it.
この回答は役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tommy Vercaty さん、ありがとうございました!
統計データを表示:
過去 24時間: 4
過去 7 日: 26
過去 30 日: 112
今までの合計 9,293
