Dropped screen is only visible with flashlight - hinges damaged
My MacBook dropped down the stairs. I have a couple of concerns:
When closed the top is skewed to the left "open section of the Apple Logo on the top". It appears that the right hinge is broken - plastic is missing from that side on the lower body. In addition, when opening the screen does not stop it continues to an almost 180 degree angle.
When I turn on the computer, I only can see the screen using a flashlight. I am able to access the hard drive and the internet.
The cover for the hinges is askew on the left side - opposite the suspected broken hinge.
It does not appear that the battery is functioning as it will not work when removed from the power supply.
Thank you for your assistance,
この質問は役に立ちましたか?
