メインコンテンツにスキップ
Repair guides and support for your Sanyo TV.
360回答 すべてを表示
Why won't my tv come on?
Sanyo 40" LCD-40XR10F Tv doesn't come on but have power. Got a blank screen.
Was working fine last night but not this morning
Any ideas would be great and if it's a quick fix can I do it myself?
Any help would be greatly appreciated
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
7 件のコメント
mitchell Apperley any sign of life on your TV? Have you unplugged it yet and let it sit for a few minutes, disconnect everything from the inputs and then plug it back in? How do you know it has power?
さんによる
Just have no picture but once I found the right channel I still had sound but still no screen
さんによる
Can it be a lamp bulb?
さんによる
Robert Robbins no bulbs there. Just a bunch of LED's
さんによる
i got the same issue on my television.
black screen: like it has no power.
the sound works as i switch via remote to tv mode.
infrared sensor shows response with remote.
can someone help.
its an 43 inch led tv
model:Sanyo 109 cm (43 inches) XT-43S7100F Full HD LED IPS TV (Black)
さんによる
2件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
mitchell Apperley seems like nothing is ever really simple when it comes to repair. Anyhow, it could be an issue with the power board if none of the things I mentioned in my comment made a difference. You want to start with something like this
which is the troubleshooting flowchart for your set. Let us know if you have a multimeter etc. to start tearing down your TV. Sanyo is a little stingy, so there are no board layouts with the schematics. For that, we will rely on you and need you to post some good images of your boards with your question. Use this guide for that.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I held down menu and -volume, pressed power 1 time, to bring up menu. Then pressed volume to change settings. It came on. If I have to go to board and all that; I will get a new tv.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
mitchell Apperley さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 37
今までの合計 13,643
