メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
782回答 すべてを表示
Battery status in menu bar doesn't work correctly
Hello there!
I've recently replaced my factory battery for a brand new Anker.
To be honest, at first i was quite disappointed. The battery duration was the same (2 hours). At least, it seemed so.
Every time the battery dropped to 10% i went running for the charger.
However, a few days ago i let it drop to 7% and discovered that the battery lasted for almost 2 hours more until it hit 0%.
So, my guess is that the overall battery duration is like 4 hours (using wifi navigation, Outlook, Word and a bit of Photoshop, at 40% brightness in Snow Leopard).
Which is good news.
But, and here is my question, how do i make the battery status indicator in the menu bar to work properly?
Because going from 100% to 10% in 2 hours and then from 10% to 0% in 2 hours it's not quite right.
Thanks in advance,
Leandro
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Let's get a real look at this baby. Please download, install run and post your results with Coconut battery.
http://www.coconut-flavour.com/coconutba...
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thanks! I've downloaded it and i'm using it. I will leave it open till the battery drops to 0%.
さんによる
コメントを追加
回答を追加する
Fokka85 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 766
