メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
様々なテレビブランドとスタイルの修理ガイドならびにサポート
6908回答 すべてを表示
Crack visible on LCD when screen is on.
My 70" SAMSUNG UA70KU7000KXXA UHD FLAT SMART TV Screen has a crack straight down the left hand side of the screen only visible when the unit is powered on. There is colour on the outskirts of the screen other than that everything is black. Sound works perfectly and it still responds to the remote.
Can this be fixed?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
Varneah Hartungyou can try to see if it is covered under warranty, but LCD damage is usually not. There is no way of fixing it. The panel will have to be replaced. This is where the real trouble starts. Panels that size are not widely available if they are at all. The cost for a replacement panel including shipping will be more than a new TV. You can try and see if you find a set that uses the same panel but has other issues than the panel and harvest the replacement from that. To search for a replacement panel, use the manufacturers label glued to the panel and not your TV model.
このアンサーは役に立ちましたか?
スコア 1
コメント:
I bought the TV on auction a few days ago and it was working perfectly. I guess it's during the transport home that it could've damaged. Cost me quite a few bucks so hopefully I can sort it out at a reasonable price. Thanks so much for your advice!!!
さんによる
コメントを追加
最も参考になった回答
Best bet would be to return it and get a new one. There are no 70" glass screens that you can buy to replace it. It should have a warranty on it.
Best of luck!
- JR
このアンサーは役に立ちましたか?
スコア 1
コメント:
Thanks JR, will try this option tomorrow. Will revert if i'm successful.
さんによる
コメントを追加
回答を追加する
Varneah Hartung さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 8
今までの合計 110
