How to replace the motor (or perhaps just the fuse)?
My immersion blender shorted out. There was a flash of light inside the housing and now it will not work. Any ideas for how to replace the fuse, or perhaps the whole motor?
Our KitchenAid model 5KHB100 started smoking while using it. Looked up instructions on disassembly and could find none.
I took this one apart, it is not screwed and clips holding the case together, it is glued and not easy to take apart without damaging it a bit. Not made to be dismantled and repaired.
I have a couple of photos of the inside.
Time to go source a replacement.
このアンサーは役に立ちましたか?
Hey Garry, any tips for unsealing the glue? Did you just use a heat gun?
Hey Mike, I didn't but could have helped if I had used one. Just pried it apart hoping there were clips to make reassembly easier.
過去 24時間: 0
過去 7 日: 3
過去 30 日: 27
今までの合計 1,762
1件のコメント
How to replace the fuse
lyamniuk さんによる
