メインコンテンツにスキップ
An audio storage device that uses magnetic tape to record and play back audio input.
29回答 すべてを表示
Playback of recorded material is "garbled"
When I am playing the recorded information from my Panasonic Microcassette Transcriber, it sounds garbled. The tape is not spinning smoothly. It seems to be held up and then let go. I tried cleaning the heads with alcohol. The problem seems to be resolved for a few minutes and then starts again. I also cleaned it with compressed air and the same thing happened. It cleared up for a bit and then started again.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Migdalia have you tried a different tape yet?
さんによる
コメントを追加
1 件の回答
ベストアンサー
The rubber drive belt inside that need to be replaced. It is Panasonic part number RDV101YA and this website says they have it:
http://www.partstore.com/Model/Matsushit...
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Glad I could help.
さんによる
Sing a note*
さんによる
Yes. At first I thought it was the tape. But it finally just stopped working. The "spindles" (I don't know what they're called) stopped turning. I opened the transcriber and found what seems to be like a little "rubber band" that was broken. I guess that's what turns the "spindles." Is there any place that I can get parts for the transcriber?
さんによる
Sounds like you need the drive belt for your recorder. What model is it? If you have the number you could try to get in touch with Panasonic and check out their parts at http://www.pstc.panasonic.com/Epartr/Par... Let us know how it is going.
さんによる
Yes, that sounds exactly like what I need! Thanks! I'm going to order it and then try to figure out how to fix it. I bought another transcriber just like it (used) so that I can keep working. I was told everywhere I called that they don't repair them. That is so absurd! Anyway, thanks so much for your help!
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Migdalia さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 13
過去 30 日: 15
今までの合計 2,296
