メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone 6 won't turn on after water damage clear up
Hi ifixit family!
The iPhone 6 dropped in a water and won't turn on anymore. I checked and remove the capacitor C5202_RF (smoked/sorted). In this process, unfortunately, I broken the resistor R5201_RF. But after this this iPhone turn on (power supply shows 0A when tunr off)... I tested the basic functions (digitizer, LCD, sim card slot) and were OK.
Checking the board I saw some "oxidation" on LCD connector and near of baseband shield, so I removed the baseband shield and the other side shield and put the logic board in UltraSonic Cleaner whit 99.9% Isopropanol . After 2 cicles of 10 minutes I brushed the board (ESD safe brush).
For my surprise after the clear up process the board won't turn on. The power supply shows 0A and when I press power button the iPhone won't turn on and the power supply still 0A.
Suggestions for look up the board problem?
Thanks and sorry my bad english
Felipe
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
最も参考になった回答
You need to use actual electronic cleaner in your ultrasonic cleaner (like Branson EC with DISTILLED water). I follow the treatment with a soak in 100% isopropyl alchohol to remove any residual moisture. Then dry it (i use a toaster oven heated to 212f . The most important part is using the correct solution in your cleaner. Alchohol is great for degreasing and flux clean up but won't fully dissolve any water corrosion or oxidation deep underneath SMD chips, etc.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Is there still a short on VCC Main?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
@thefix0702
I will looking for these solutions next time... thanks for the tip
@teetopp01
No, after I remove the C5202_RF the short is gone
updade: I removed all shields and check on a microscope and don't find any "issue" like components smoked or corroded.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Felipe Kashiwagura さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 406
