Battery install without adhesive?
I messed up the adhesive strips so I cannot use them. Can I install the battery without the strips until new ones arrive?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Yes, you can, but you risk damaging other components in the phone or the new battery cables. The risk of the battery moving and causing problems is slight, but there is always a chance. I would suggest waiting until the adhesive comes.
このアンサーは役に立ちましたか?
The reason the iPhone batteries are held down with the silicone original tape is for heat transfer in an attempt to prevent battery from overheating , using correct will prolong battery life
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 1
過去 30 日: 3
今までの合計 2,171
