Touchpad seems slow and sluggish
How do I test the touchpad because it seems stuck sometimes. Is it replaced by replacing the upper case?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
It looks like the problem is an old battery. Apparently as they age they swell and push up from below and affect the Touckpad.
Replaced the battery....problem solved.
このアンサーは役に立ちましたか?
Try going under the system preferences, go to trackpad, and adjust the settings as you see fit.
このアンサーは役に立ちましたか?
Yeah, it might be that the cursor speed is set too low for your liking.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 4,976
