メインコンテンツにスキップ
カセットプレイヤーの修理ガイドならびにサポート
85回答 すべてを表示
The Cassette deck in my car doesn't play music! Please help
It was working just fine. Then it started making these high pitched sounds whenever I had the iPod adapter playing. Now it won't play any tapes at all. The radio still works, so I know I didn't just blow out the speakers or something. It still sounds like it's spinning the tape and it doesn't eject or rewind anything.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
The most likely culprits are
#1 the belt that controls the cassette mechanism has gone bad/loose or broken
  1. 2 the switches that control the mechanism are dirty or broken
Both would require removal of the unit from the car and you'd need to bring it to a electronics repair shop. Any decent tech would charge $75-125 to do it right. They'd also clean the heads and tape path, so it'll probably sound a lot better once they are done. good luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Shelly さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 39
今までの合計 10,111
