Why is my battery getting so hot its shuttin device down after a new
Bought a new battrty installed it now it gets super hot shuts off and doesnt hold a charge
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Deb. My initial thought is that the soldering of the battery connectors may not have been successful. Too much heat applied could damage the battery flex cable (causing a partial short) or damaging the logic board.
I would open up the device and do a thorough visual inspection of the battery connector area.
It is also possible that you received a bad battery. If you are confident in your soldering skills, then you could put back the old battery to see if the excess heats goes away.
このアンサーは役に立ちましたか?
Thank you i will check it out
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 48
