メインコンテンツにスキップ
Appleは2880×1800ピクセル標準解像度でRetinaディスプレイを装備した新しいデバイスを発売しました。
3606回答 すべてを表示
Pages wont load content properly. (still loads base data)
What Facebook SHOULD look like
What It looks like now.
Above is an image of how webpages load. I would like an answer on how to reset safari's data, and if that does not work, any ideas you will have on how tto rectify this issue without completely factory resetting the device. (that comes later)
the device is currently running 10.10.5
+ +UPDATE+ +
I have downloaded a new browser, (Firefox) which works fine. Which means the system itself has no issues with data packets, but it is safari itself. I have returned all preferences to default, and cleared history.
I am unable to get safari to work, even while running Disk Warrior.
Ran DiskWarrior, which found 4 damaged Resource Files. ".jproj" files
Any addition support will help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
コメントを追加
4件の回答
ベストアンサー
i've found the issue. Date and time wasnt updating autmatically, even though it was set to.
I updated the time, and it force a JAVA update. once the update went through, i was able to get the images properly. thank you for all your time and effort
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
最も参考になった回答
If your not in full screen mode, then:
Go to View -> Customize Toolbar...
Then, perform the "...drag the default set into the toolbar" option.
Now, go to the View drop down again and the Hide/Show Toolbar option should be accessible.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
ive followed your steps. this option still does not exist in the "view" Drop down
however, the toolbar is not what im looking for. im looking to fix Facebooks loading from what the image posted looks like, to its proper layout. its like its not loading the pages graphics.
さんによる
Please tell us exactly which Retina machine you have and what OS X version your are running. Posting an image from say this page might help us to understand your problem more completely as I can't tell, on your original image, what it's supposed to look like.
さんによる
sorry, ive never run into someone who hasnt used facebook before. im not talking about a screen issue. it has nothing to do with hardware. above, i have posted an image of what the facebook login page is supposed to look like.
さんによる
Scott thanks for the down vote.
さんによる
コメントを追加
I've seen this happen sometimes, I've always attributed it to some key files being lost or corrupted; i.e. the data that goes on the page made it to you but the data that describes how to lay it out did not. (CSS or something like that.)
When It's happened to me it's usually been a transient problem, so I always attributed it to a critical packet getting lost.
If it's consistently happening with facebook there could be some form of filtering proxy between you and facebook, or it could be that your browser is sending out a very old user-agent string and facebook is responding with a simplified page.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
but its not facebook alone. its every web page, all the time. how would i be able to rectify this?
さんによる
and it works fine on a seperate browser.
さんによる
コメントを追加
Is it like this with any other sites? Or just facebook?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
all websites. im just using facebook as an example.
さんによる
You already cleared browsing history and cashe?
さんによる
コメントを追加
回答を追加する
Scott さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 136
