メインコンテンツにスキップ
Lenovo社によって製造されたラップトップモデルの修理ならびにサポートガイド。
2562回答 すべてを表示
My Lenovo Mouse isn't working right
My mouse suddenly stopped responding when i moved it and the red light scanner for movement is turning on. The mouse registers that it has power because the lights on the mouse turn on if you hit a couple of its buttons. The mouse also doesn't automatically turn on its lights. None of the buttons on it work either. I have tried blowing the the USB connector but that didn't help i tried force connecting the mouse the the computers settings but hat didn't work i also tried turning the mouse on and off but nothing happened and finally i tried unplugging my mouse from my computer but that also did not help i am at a loss i don't know what to do please help me
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 8
2 件のコメント
i have this problem too and it won't
freaking work :(
さんによる
i think i have this problem i have a lenovo gaming mouse
and yesterday i cleand my desk but suddenly about 2 hours later
it just moved by itself and clecking somethings thin also roblox turned on by itself and today same thing happened it didnt respond at first but i unplugged it then i plugged it again but after i plugged it in
i wasn't able to click anything i turned off my laptop then started it again
then it worked perfectly
if someone know this problem or know how to solve it please reply
ideapad gaming lenovo mouse
さんによる
コメントを追加
2件の回答
最も参考になった回答
This may be a driver issue. Depending on version of Windows, right click on the Start button and select Computer Management and then select Device Manager. Check to see if your mouse is listed under Human Interface Devices or Mice and Other Pointing Devices. Right click on the mouse entry and select uninstall, if you are prompted to delete the drives click yes. Click on the Actions tab at the top and select Scan for Hardware Changes. This should update the driver for the mouse.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you- what if the mouse isn’t listed but it’s been working fine all along, and now suddenly it’s not. Devices are updated as far as I can tell. Batteries are changed too!
さんによる
コメントを追加
I had to charge my computer so I can study for my quiz and I turn it back on so I can do my homework and the mouse stopped working I don’t really know what the problem is I just need a solution to fix this
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kira さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 38
過去 30 日: 187
今までの合計 23,312
