メインコンテンツにスキップ
バッテリーのアップグレードやディスプレイの修理を含むSPS Goの完全修理マニュアルです。
88回答 すべてを表示
Psp go wont turn on?
my psp is not working help
the other day my psp downloaded a game called beaterator and when i was playing the game it died, suddenly it wouldn't turn on after that and i was like "i will destroy you" so then i grabbed the usb cord and plugged it into a wall charger but it didn't charge, then i plugged it into the computer and nothing still! should i send it to Sony? :O i want to curse them out lol
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
3件の回答
最も参考になった回答
Tommyrunsnaked, have you tried to:.
Try a hard-boot (Hold the Power button up for 10 Sec.)
Try to take out the battery and let it out for let me say 5 Min.
Connect the AC WITHOUT the battery and try to power on.
Let us know if this is working for you, if not we can try to find another solution for you. Good Luck
このアンサーは役に立ちましたか?
スコア 5
3 件のコメント:
it still didn't turn on
さんによる
thanks :D:D !&&* yeah my psp turned on
さんによる
My power button is broken. Can you tell me another way to switch it on
さんによる
コメントを追加
HI all i was having almost same problem...... I removed the battery and test without it. Now it is working. but if i put battery back it is not working again..... any suggestions
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Change your battery. Possibly its your battery that is shortening out the circuit....:-)
さんによる
コメントを追加
Hi, i Have a problem, i already tested with no battery and dont turn on, I think its the button on off its damage in the circuit, but my problem its where the energy in and out in the button in the circuit. Its charged the battery in psp and i test de battery and mesaure and its good. sometimes in the past the button failed when we turn on, doesnt work now, possible its the button on off. How i measure the button to see if its ok or not ok. Please help me . This Button have 4 pin and i dont now the direccion of the energy to mesaure or see if it are damage or shortening. Thank you for help.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tommyrunsnaked さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 23
過去 30 日: 100
今までの合計 21,584
