camera & other applications message
why do i get message to close other applications when i use the camera?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I would try to remove the battery. Once the the battery is out remove your SD card and put it back in securely then put the battery back in and restart the phone. If this does not work you may have to completely wipe and reload your OS. BTW the manual for your phone is available at http://docs.blackberry.com/en/smartphone... and may help you to determine what is going on further. Good Luck
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 16
今までの合計 1,827
