I need a Repair Manual?
MFC-3240C began with error "Unable to Clean" then error 46, now it's saying "Paper Jam" ! If i had the repair manual I could fix this myself. Also need to reset all the maintenance settings.
You might want to take a look and see if something is actually jammed or stuck (I often find loose pens causing carriage stalls), it may not be a false positive, but an actual issue.
このアンサーは役に立ちましたか?
Here is a link to a site where you can obtain your manual. Arrow down to the middle of the page and you will find a link to get this manual.
Good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,674
Deleted my link because they changed to a charge instead of free.
rj713 さんによる
Ronald Massey, here is the user manual and that can help you clearing some of the errors. http://www.fixya.com/support/p170050-bro... still looking for a service manual for you.
oldturkey03 さんによる
