メインコンテンツにスキップ
修理を始めるには
修理する権利
ストア
1.8 GHz デュアルコア Intel Core i5(Turbo Boost使用時最大2.8 GHz)3MB L3キャッシュ
397の回答 すべてを表示
Half of the screen's lights are not working and it flickers
Hi
I have been having sleepless nights with this issue.
The light on the screen of my Macbook is not functioning well. The issues are:
1. The light is flickering
2. Half of the screen is well-lit and the other half is dim
3. The screen looks like inside it are 'light bulbs'
Please see attached image.
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
First hook it up to and external monitor to help isolate the issue.
この回答は役に立ちましたか?
スコア 2
コメントを追加
Was the device dropped at all? It appears as if your backlight is having issues. You may need a display replacement to fix the issue.
この回答は役に立ちましたか?
スコア 1
コメント:
It wasn't dropped but I remember I bumped this into a table then there was also 1 instance when my juice spilled inside my bag and the part where you flip the laptop got wet but I was able to clean it up after a few mins
さんによる
It sounds like the display was compromised. A display replacement will fix the issue, unless the laptop has liquid damage on the motherboard where the display connects to it. Then your computer may have further irrepairable damage.
さんによる
Ouch :( would you recommend having it fixed or better for me to just purchase a new one?
さんによる
Fixed. As a Pro in the iFixit community, we are here to fix your devices. A display, motherboard, etc can always be fixed.
さんによる
コメントを追加
回答を追加する
Angel Lou さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 91
