メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
iPhone 6 no image, but found in itunes
Replaced the screen on an iPhone today, where the screen was loose from the frame due to poor quality. The phone had no image previously, but when I installed a new screen and powered it on (it had been sitting for months), it would not show an image. Have tried a new screen, restoring, ect ect. I have the data recovered, but would very much like help to how I can get the screen working
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Does the phone work with the original, presumably cracked screen? Based on your question, its hard to say if this phone was in a working condition or not.
It appears you have either a defective replacement screen or there is a backlight driver issue on the logic board. Connect your phone to iTunes and shine a bright flashlight on the screen. If you can see a dim image, then you have a blown backlight circuit and this will require a micro-soldering repair.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
hi, thanks for your reply if this helped to @sonnicham
I unplugged the screen connectors while iphone is on and now no image on phone but itunes can find my phone and I am sure phone works and home button works. I tried hold flashlight on the screen but can't see anything.
さんによる
コメントを追加
回答を追加する
Sonnicham さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 130
