メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
アクティブユーザー向けに設計されたPowerBeats2 ワイヤレスヘッドホンの修理ガイド。
Headphones were washed and won't work!
How to fix washed headphones so they work again, if possible?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It's not surprising that your headphones do not work after washing. Did you dip them in water or just wiped them with a wet cloth? In any case, if water has entered the headphones and you can dismantle the covers, etc. check whether you can find wet parts. If you find water inside any place wipe it carefully with a dry cloth or paper napkins and leave them open to dry in the air. If this was the cause they should work once you put them back together. Of course there is always the chance that the water may have shorted and burnt some components in which case send them to the service facility or buy yourself a new pair (it may be cheaper than having them repaired). Oh, don't forget to check the batteries too.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
AnTHoNY FuCcI 18 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 17
今までの合計 1,748
