Can I replace only the housing of 5s with the Rose Gold iPhone SE
Hey iFixit! I have a query regarding the iPhone 5s, could you please answer it; if I can replace only the housing panel of IPhone 5s with the Rose Gold IPhone SE?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I haven't tried this myself but technically speaking, you can put the 5S internals in an SE housing but the opposite is not true. You will have to transfer over everything as the rear camera, Lightning Port and battery have different connectors between the two models.
Check this link for more info.
このアンサーは役に立ちましたか?
If you want a SE housing, you'll need change with all parts (charging port, power cable Etc ...). It's not worth it!
このアンサーは役に立ちましたか?
Can I put all my internal of 5s to an iPhone SE housing
Need All Accesorios transfer
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 300
