Glass only repair with dry ice
Can you perform a glass only repair with dry ice on the S8? I know it can be done with liquid nitrogen.
You can replace the glass only with a freezing machine.
このアンサーは役に立ちましたか?
Can you elaborate on how this is possible?
Better yet, what is the temperature output by a freezing machine?
@avanteguarde Here you can see how it works and temperature
It appears as though a literal freezing machine like the one mentioned by the users above will do the trick. Dry Ice (solid CO2) doesn't appear to be cold enough.
このアンサーは役に立ちましたか?
What is the name of this machine? Where do you buy it?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 4,396
