メインコンテンツにスキップ
2014年9月19日に発売されたこのiPhoneは4.7インチのスクリーンサイズでiPhone 6 Plusの縮小版です。
4794の回答 すべて表示
Phone screen shuts off several days after screen replacement
Following the screen repair of an Iphone 6, iphone 5s, iphone 6 plus, and iphone 6s the screens appear to work perfectly; however, the owners of each of these phones had issues several days and in most of the phones several weeks following the repair. The 5s, 6, 6 plus all shut off and wouldn't power on while the 6s became unresponsive to touch. I have repaired many phones before this without ever having this issue. Is it something I may have damaged during the repair, bad screens, or just an issue with the phone that a screen repair is guaranteed to fail because of some other issue with their devices?
Any insight on the matter is greatly appreciated
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
iPhone X用修理キット
Warranty up? No worries, we’ve got the fix.
ショップを見る
iPhone X用修理キット
ショップを見る
1回答
最も参考になった回答
I would suspect that with such a high failure rate on separate devices that the parts you are using are defective. I would try a screen that you know is from a separate supplier if available and see if the problem persists.
この回答は役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
David Mendonsa さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 22
