メインコンテンツにスキップ
A collection of guides and support to help with washer repair.
3473回答 すべてを表示
GE washer model GTUP240EM1WW won't lock
I was doing a load of laundry and the washing machine was thrown off balance. So I stopped the machine and tried to rebalance the load. When I went to go start the spin cycle the lid won't lock. It makes five clicking noises and nothing happens. I put it into diagnostics mode and it says there's no errors.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Unplug the machine for 5 minutes to allow it to reset.
Plug it back in and see if the code persists
5 flashes - Clear code and if problem still exist replace motor.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
@cccorliss27 I know that you said you ran a diagnostics test, this is just to make sure that we are all on the same page. Run the test according to the manual. If nothing else you will also want to look at the washer control board on connector J4 to see if there are any issues with the lid switch.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
Where exactly is the control board?
さんによる
Yours is a wisher dryer combo correct? Let me see if I have that complete manual for you to get to the board.
さんによる
That is correct.
さんによる
コメントを追加
回答を追加する
Charles corliss さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 5
今までの合計 2,369
