How do I remove the lower radiator hose?
I am replacing my radiator in my 2001 VW Jetta and cant get the lower radiator hose off. I pulled the clip off but am not sure how to pull off the hose with out braking it since its all plastic.
See if this video points you in the right direction.
このアンサーは役に立ちましたか?
How do I remove parts to get to the radiator upper hoes and lower horse
I went under the car and took the fan off i took off the lower hoes off but I can’t take off the upper hoes because of the clamp it’s facing up and I can get to the teeth to open it
It’s the hoes from the under vw Jetta 2005
このアンサーは役に立ちましたか?
Buy some LONG pliers "BFPs". Don't worry - Harbor Freight is cheap, & you'll use them all the time.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 3,440
