phone will not charge battery after screen replacement/says battery to
I changed a broken screen out on a Samsung Galaxy S8 plus after changing the screen all functions worked well except the charge. when ever i try to charge it is says charging paused battery to cold. I have tried changing the charger flex and a new battery . it still says charging paused because the battery is to cold. where is the components that detect battery temp ?
この質問は役に立ちましたか?
1件のコメント
Hi. I had the same issues with some s8 phone (8 and 8+). Some of them got back working but the last one gave me troubles. For 2 weeks i have tried to change the charging flex, battery, screen. nothing made it word. I was trying to look after solutions, and i found something interesting. I just assemble the the phone with screws and problem solved for me. It is maybe like for some acer laptop models where you need to put the screws so it can charge the battery. I have another one now (s8) with the same issue. Came is into our repair shop, charge it, put it on a heat plate at 90 degrees, change the screen, plug it to charge, boom, battery problems again. I assemble again the phone, phone is charging great. I hope will be an extra info and hope you can fix it. Thanks KEITH for the post.
rubiosantos さんによる
