メインコンテンツにスキップ
The Toyota Platz is a supermini automobile that was manufactured in Japan by Toyota from 1999 through to 2005. Designated by Toyota as the XP10 series, the Platz was sold in export markets as either the Toyota Echo or Toyota Yaris.
15回答 すべてを表示
Airco cooling is not working, but the fan stil working and drive
Good day sir,
I have a 2002 Toyota Platz. When starting car running the air conditioning me good, but after a while the cooling falls as a half an hour away. What I have noticed that only the fan runs. What can be the cause of it?
Regards,
Gili
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Thank you sir for the information. it was helpful.
さんによる
コメントを追加
1 件の回答
選択されたソリューション
There is a coil in the ac compressor that engages the ac clutch but over time the gap between the clutch and the coil becomes wider which causes it not to engage the ac clutch correctly. Two shims control the length of the gap and they either need to be filed down or one or both need to be removed as the ac coil gets weaker over time. Look in the chilton's manual about checking the ac clutch gap.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Shake さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 109
